Knowledge Base Article
Why is SMMU event 0x10 observed during AES-GCM decryption for payloads ≥ 4MB?
Description
Due to a problem between the ESW components and the memory subsystem, you may observe SMMU events on certain boards while running the FCS use case (AES GCM).
This problem does not impact the functionality of AES-GCM encryption or decryption.
The SMMU Event 0x10 was observed during AES-GCM decryption with payloads ≥ 4MB, using the following ESW components:
| SW Component |
Branch/tag/Version |
Commit |
LibFCS |
main |
5e394f8389c2e5c1a638058881e5c226fe9f7a51 |
Linux |
socfpga-6.12.19-lts |
7b88569116a96ce8323da2656c5a5018b920d9ff |
Command used:
root@agilex5dka5e065bb32aes1:~/run_dir/cs# ../fcs_client -Y -s 3296e0b8-e777-354a-8941-1e719cb803f5 -n 11 -k 35 -b 3 -m 0 -f iv.bin -u aad.bin --tag tag.bin -i data_4194304.bin -o aes_enc_10_4194304.out -v;../fcs_client -Y -s 3296e0b8-e777-354a-8941-1e719cb803f5 -n 11 -k 35 -b 3 -m 1 -f iv.bin -u aad.bin --tag tag.bin -i aes_enc_10_4194304.out -o aes_dec_10_4194304.out -v
AES Crypt successful
[ 611.344327] arm-smmu-v3 16000000.iommu: event 0x10 received:
[ 611.350162] arm-smmu-v3 16000000.iommu: 0x0000000a00000010
[ 611.355779] arm-smmu-v3 16000000.iommu: 0x0000020a00000000
[ 611.361404] arm-smmu-v3 16000000.iommu: 0x000000001fc00000
[ 611.367034] arm-smmu-v3 16000000.iommu: 0x0000000000000000
Resolution
This problem is scheduled to be fixed in a future release of the embedded software components.
