Knowledge Base Article
Why is a JTAG ID code error issued during configuration or programming with a JAM or JBC file?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software vesion 22.3 and earlier, you might see the following JTAG ID code error during configuration or programming with JAM or JBC file.
<< Intel® Quartus® Prime Programmer Tool >>
Error(209001): JTAG ID code specified in JEDEC STAPL Format File does not match any valid JTAG ID codes for device. Verify that the target device's location on the circuit board matches the device's location in the device chain.
<< quartus_jli command >>
Info: Command: quartus_jli -a CONFIGURE example.jam
Device #2 IDCODE is FFFFFFFF
Device #1 IDCODE is FFFFFFFF
Unrecognized device
Exit code = 6... Unrecognized device
Resolution
To avoid this problem, use the Intel® Quartus® Prime Pro Edition Software version 22.4 or later.
Updated 11 months ago
Version 3.0
