Knowledge Base Article
Why doesn't the Quartus II pin report show VREF pins being used in I/O banks with HSTL or SSTL output pins?
Description
The Quartus® II pin report will not show VREF pins being used if the bank where the VREF pin is located contains only HSTL or SSTL output signals. VREF pins are only referenced by SSTL or HSTL receivers (I/O configured as inputs or bi-directional pins).
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
