Knowledge Base Article
Why does the Triple Speed Ethernet Intel® FPGA IP receive packet error in 10/100Mbps when the MAC's local loopback is enabled?
Description
The Triple Speed Ethernet Intel® FPGA IP received packet error in 10/100Mbps when the MAC's local loopback is enabled.
Resolution
The following patch provides a solution to fix MII local MAC loopback issue.
Download the appropriate Quartus® II software version 10.0SP1 patch 1.210 from the following links:
Caution:
You must either have installed the Quartus II 10.0 SP1 software previously  or install the Quartus II 10.0 SP1 software before installing this patch. Otherwise, the patch will not be installed correctly and the Quartus II software will not run properly.
After you have installed the patch, regenerate your Triple Speed Ethernet Intel® FPGA IP before you compile your design.
OR
Download the appropriate Quartus II software version 10.1SP1 patch 1.77 from the following links:
Caution:
You must either have installed the Quartus II 10.1 SP1 software previously or install the Quartus II 10.1 SP1 software before installing this patch. Otherwise, the patch will not be installed correctly and the Quartus II software will not run properly.
After you have installed the patch, regenerate your Triple Speed Ethernet Intel FPGA IP before you compile your design.
Updated 4 months ago
Version 4.0
