Knowledge Base Article
Why does the rx_freqlocked signal get stuck high for an Rx only transceiver instances in Cyclone® IV GX devices?
Description
You may see the rx_freqlocked signal get stuck high for an Rx only transceiver instance due to a bug in Quartus® II software versions 12.0 SP2 and earlier software.
Resolution
To fix this problem in Quartus II 12.0 SP2 install patch
This issue will be fixed in a future version of the Quartus II Software.
Updated 4 months ago
Version 4.0
