Knowledge Base Article
Why does the Quartus II programmer display a JTAG USERCODE of 0xFFFFFFFF when programming with a .jic file, even when I have defined a unique JTAG USERCODE in my FPGA design?
Description
The Quartus® II programmer will display a JTAG USERCODE of 0xFFFFFFFF when programming with a .jic file, since a .jic is used to program an EPCS device which does not have a JTAG USERCODE field. This requires the FPGA to be configured with a Serial Flash Loader (SFL) image, which has a default usercode of 0xFFFFFFF.
The .sof generated for your FPGA design will contain the USERCODE as specified in your design and this is preserved when the file is converted to a .jic. Hence your unique USERCODE (if specified) will be programmed into your FPGA when it configures from the EPCS device, rather than 0xFFFFFFFF.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
