Knowledge Base Article
Why does the Modelsim® 5.8 SE simulator disappear when I perform a Verilog HDL functional simulation?
Description
The Modelsim 5.8 SE simulator crashes and disappears when you load a Verilog HDL design containing a generate block that refers to a design name (such as the port of a module) that is not declared as a wire type.
As a work around, create a new wire and assign the wire to the design name. In the generate block, refer to this wire.
This problem has been fixed in version 6.0 of the Modelsim simulator.
Updated 2 months ago
Version 2.0
