Knowledge Base Article
Why does the Intel® Quartus® Prime Pro Edition Software v21.3 fail to compile in the Support-Logic Generation stages when the design has more than one FGT PMA channel clocked with PMA clocking mode?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software v21.3, if you configure more than one FGT PMA channel with physical medium attachment (PMA) clocking mode in your design, you will run into a known compilation error. This problem happens at the Support-Logic Generation stages during the compilation process. This problem affects the FGT PMA type for both non-return-to-zero (NRZ) and PAM4 mode.
FHT PMA type and System PLL clocking mode for FGT PMA are not affected by this problem.
Resolution
This problem is scheduled to be fixed in a future release of the Intel® Quartus® Prime Pro Edition Software.
Updated 11 months ago
Version 3.0
