Knowledge Base Article
Why does my ball-grid array (BGA) package have small metallic bumps between or beside the solder balls?
Description
BGA packages for certain devices have small metallic bumps located between or beside the solder balls of the package designed to act as ground plane pads to cover the vias connecting the device's ground traces to the package's ground plane.
These pads are smaller than the device's solder balls and are located far enough away from the individual solder balls that they will not cause shorts during reflow. These bumps are made of high temperature solder that will not melt during a regular reflow process where the peak reflow temperature does not exceed Altera's specified peak temperature (220 ºC).
You should ensure proper alignment of the part during pick-and-place by aligning the part based on the package outline rather than the location of the balls. Make sure that the thickness of the solder is not too high. If the solder is too high, it will cause shorts from the solder migrating to other balls as well as the ground pads.
Updated 11 months ago
Version 3.0
