Knowledge Base Article
Why does internal adaptation of the Intel Agilex® 7 FPGA F-Series E-Tile 100G Ethernet PAM4 design example always fail in the Ethernet Toolkit ?
Description
Due to a problem in the Ethernet Toolkit of the Intel® Quartus® Prime Pro Edition Software, v21.2, internal adaptation failure might occur for E-Tile 100G Ethernet PAM4 design example targeting the Intel Agilex® 7 FPGAs F-Series. This is because Channel0 or Channel1 loopback mode is wrongly set to OFF during internal adaptation.
Resolution
To work around this problem in the Intel® Quartus® Prime Pro Edition Software v21.2, you may change the loopback mode to serial loopback in the Transceiver Toolkit manually during internal adaptation.
This problem has been fixed in the Intel® Quartus® Prime Pro Edition Software v22.3.
Updated 11 months ago
Version 3.0
