Knowledge Base Article
Why do led_char_err and led_disp_err signals of the Arria 10 1G/2.5G/5G/10G Multi-rate Ethernet PHY IP Core remain high for one clock cycle when led_link signal becomes high?
Description
When using the Arria® 10 1G/2.5G/5G/10G Multi-rate Ethernet PHY IP Core, you may see led_char_err and led_disp_err signals remain asserted for one clock cycle after the led_link signal asserts.
Resolution
You can ignore the led_disp_err and led_char_err signals for the first clock cycle after the led_link signal asserts. This is the expected behavior.
Updated 11 months ago
Version 3.0
