Knowledge Base Article
Why do I see bit errors on RX channel 0 of transceiver block GXBL1 when I de-assert the gxb_powerdown signal of transceiver block GXBL0 when using Cyclone® IV GX EP4CGX150 and EP4CGX75 devices?
Description
You might see bit errors on RX channel 0 of transceiver block GXBL1 when you de-assert the gxb_powerdown signal of transceiver block GXBL0 when using Cyclone® IV GX EP4CGX150 and EP4CGX75 devices due to coupling inside the device.
Designs that might be affected are:
  • Cyclone IV GX EP4CGX150 and EP4CGX75 devices that use transceiver banks GXBL0 and GXBL1
  • RX channel 0 in transceiver bank GXBL1 is used
  • TX Channel 3 in transceiver bank GXBL0 is used
  • The gxb_powerdown signals of transceiver banks GXBL0 and GXBL1 are controlled independently.
Affected designs may need to be resynchronized.
Resolution
To work around this problem, do not use the gxb_powerdown signal for transceiver bank GXBL0. Instead you can assert the pll_areset, tx_digitalreset, rx_analogreset, and rx_digitalreset signals.
Updated 11 months ago
Version 3.0
