Knowledge Base Article
Why do I get the same timing results for all timing corners when using Design Space Explorer?
Description
In the Quartus® II software, Design Space Explorer (DSE) may report the same results for fall timing corners if your Synopsys Design Constraints (.sdc) file contains aset_operating_conditions command.Resolution
To avoid this behavior, remove theset_operating_conditions command from the .sdc file.Updated 11 months ago
Version 3.0No CommentsBe the first to comment
