Knowledge Base Article
Why do I get the error: "Text Design File syntax error: Text Design File contains '(', but must contain ASSERT, CONSTANT, DEFINE, DESIGN, FUNCTION, OPTIONS, PARAMETERS, SUBDESIGN, or TITLE"?
Description
This error may occur in the Quartus® II software when you are:
  • Converting a design originally created using the MAX PLUS® II software.
  • Using library of parameterized modules (LPM) functions created in the Altera® Hardware Description Language (AHDL) in your design.
The error is caused because you are including inst.tdf files, which are created with the MegaWizard™-generated LPM files, in a Quartus II project. inst.tdf files are only for reference when instantianting LPM functions in a project. Remove these files in order to fix the error.
Similar errors will occur for VHDL and Verilog HDL if these files are added to the project.
Updated 11 months ago
Version 3.0
