Knowledge Base Article
Why do I get a "Device Programming Failure" error when programming devices using the stand-alone DOS Jam STAPL Player with the ByteBlaster® II download cable but not when using the Quartus® II Programmer?
Description
The stand-alone DOS based Jam Standard Test and Programming Language (STAPL) player is not compatible with Byteblaster II download cables.   The driver in the stand-alone DOS Jam STAPL player is designed only to work with ByteblasterMVTM download cables. Try using the ByteBlasterMV download cable if you have this problem when using the stand-alone Jam STAPL Player.
In a future version of the Quartus II software, a stand-alone Jam STAPL Player executable will be installed that can run on DOS and supports all Quartus II supported download cables including the USBblaster download cable.
Updated 11 months ago
Version 2.0
