Knowledge Base Article
Why can't I use the x1 line to clock Arria® V device transceiver channels higher than 6.5536 Gbps within a transceiver bank but across a triplet boundary when using Quartus® II software version 15.0.1 and earlier?
Description
Due to a bug in Quartus® II software version 15.0 Update 1 and earlier, the Fitter will prevent you from clocking Arria® V device transceiver channels higher than 6.5536 Gbps within a transceiver bank but across a triplet boundary.
Resolution
To work around this problem, install the Quartus® II software version 15.0 Update 1 and then download and install patch 1.07 from the links below.
- Download the Quartus II software version 15.0 Update 1 patch 1.07 for Windows (.exe)
- Download the Quartus II software version 15.0 Update 1 patch 1.07 for Linux (.run)
- Download the Readme file for the Quartus II software version 15.0 Update 1 patch 1.07 (.txt)
This problem has already been fixed in Quartus® standard software version 16.1.
Updated 3 months ago
Version 3.0No CommentsBe the first to comment
