Knowledge Base Article
Why can’t I find guidance on how to access the SDC cookbook for JTAG signal constraints from the Download Cable II User Guide?
Description
In the Download Cable II User Guide, Section 2.7: JTAG Timing Constraints and Waveforms, there is no guidance on how to access the SDC Cookbook for JTAG signal constraints.
This may lead to confusion for users who need to apply timing constraints correctly when using the Download Cable II.
Resolution
Follow these steps to add the JTAG signal constraints template from the SDC Cookbook:
- Navigate to File > New > SDC File, then click OK.
- In the newly opened SDC file, right-click and select Insert Template.
- In the Insert Template window, go to:
- Timing Analyzer > SDC Cookbook > JTAG Signal Constraints
Include the following note to clarify usage:
- Users may adjust the Download Cable II (USB Blaster II) cable length to match their design.
- Do not modify the USB Blaster parameters listed below, as they are critical for proper operation:
set tck_blaster_tco_max 14.603
set tck_blaster_tco_min 14.603
set tms_blaster_tco_max 9.468
set tms_blaster_tco_min 9.468
set tdi_blaster_tco_max 8.551
set tdi_blaster_tco_min 8.551
set tdo_blaster_tsu 5.831
set tdo_blaster_th -1.651
Related Articles
Updated 3 months ago
Version 3.0No CommentsBe the first to comment
