Knowledge Base Article
Why are my SOPC Builder clocks undefined in simulation when using ALTPLL in SOPC Builder to generate these clocks?
Description
This is a known issue with Quartus® II software version 10.x, and is associated with the definition of 'pfdena' in the ALTPLL megafunction when "Created an 'pfdena' input to selectively enable the phase/frequency detector" is not enabled in this megafunction.
The workaround this issue enable this option in your ALTPLL function within your SOPC Builder system. This can be done by:
- Open your SOPC Builder system
- Select the ALTPLL block, and select Edit
- In the ALTPLL block, go to page 2 (Inputs/Lock) and enable "Create an 'pfdena' input to selectively enable the phase/frequency detector".
- Click Finish, Finish in the ALTPLL block.
- Regenerate the SOPC Builder system.
- Select Run Simulation from SOPC Builder - being sure that SOPC Builder Tool > Options... HDL Simulator Options path is properly set.
This issue will be fixed in a future version of Quartus II software.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
