Knowledge Base Article
Why am I unable to use the eq[] port when instantiating the LPM_COUNTER using the MegaWizard® Plug-In Manager? (MAX PLUS® II)
Description
The LPM_COUNTER declaration in the MAX PLUS® II Help topics shows an optional eq[] port. It also mentions that this port is only available for Altera hardware description language (AHDL). This port is no longer supported in the MegaWizard Plug-In Manager. However, the port is still listed in the AHDL declaration for backward compatibility with older AHDL designs. It cannot be used with any other design entry method. The eq[] port is not supported by the LPM220 standard.
Resolution
Altera advises that you do not use this port in future designs because behavioral simulation will not be possible.
Updated 11 months ago
Version 3.0
