Knowledge Base Article
When should the Disable EPCS/EPCQ ID Check option be enabled in the Convert Programming Files utility?
Description
You may turn on the “Disable EPCS/EPCQ ID Check” option in the Convert Programming Files option when you want to generate programming files which disable the EPCS/EPCQ ID check performed by the FPGA when it configures from EPCS/EPCQ. This option will not disable the ID check performed during programming of the EPCS/EPCQ devices by Quartus® Prime software.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
