Knowledge Base Article
When in the configuration process will the CRC_ERROR pin be driven low if enabled?
Description
When the CRC_ERROR function is enabled, the CRC_ERROR pin will begin to drive low once the device enters usermode. If you have the optional INIT_DONE pin enabled then the CRC_ERROR pin will be driven low once INIT_DONE is released and pulled high via the external pull-up.Updated 11 months ago
Version 3.0No CommentsBe the first to comment
