Knowledge Base Article
What is the RGMII TX_CLK clock period timing tolerance in Arria® V Device Datasheet?
Description
Due to a problem in the Arria® V Device Datasheet, the Min/Max value for the TX_CLK period is not provided in the Ethernet Media Access Controller (EMAC) timing characteristics table in the HPS specifications section.
Resolution
Refer to Table 1 for the Tclk Min/Max specifications.
| Symbol | Description | Min | Typ | Max | Unit |
| Tclk(1000Base-T) | TX_CLK clock period | 7.2 | 8.0 | 8.8 | ns |
This problem is scheduled to be fixed in a future release of the Cyclone® V/Arria® V Device Datasheet.
Updated 1 month ago
