Knowledge Base Article
What is the reset value for csr_waitrequest signal of 10-Gbps Ethernet MAC MegaCore Function?
Description
The behavior of csr_waitrequest signal follows Avalon Interface Specifications (PDF). When an Avalon®-MM master is idle, the master must make no assumption about the assertion state of csr_waitrequest. The csr_waitrequest may be high or low.
Updated 2 months ago
Version 2.0
