Knowledge Base Article
What is PCI? What are the typical applications of a PCI bus?
Description
The PCI™ (Peripheral Component Interconnect) Local bus is a high performance 32-bit or 64-bit bus with multiplexed address and data lines. The bus is intended to be used as an interconnect mechanism between highly integrated peripheral controller components, peripheral add-on boards and processor/memory systems.Updated 11 months ago
Version 3.0No CommentsBe the first to comment
