Knowledge Base Article
What does bit 7 of the Scatter Gather DMA descriptor status field indicate?
Description
I noticed while simulating the SGDMA, bit 7 of the descriptor status field was being updated to a '1'. The Embedded Periperals IP User Guide defines the 8 bits of the descriptor status as an error field. What error is indicated by bit 7?
In a stream to memory configuration if bytes to transfer is set to 0, a transfer will continue until an end of packet is recieved. Bit 7 of the SGDMA descriptor status field is updated indicating that an end of packet was received during the processing of this descriptor.
Updated 11 months ago
Version 3.0
