Knowledge Base Article
What are the differences between ambient temperature, junction temperature, storage temperature and operating temperature?
Description
The storage temperature (Tstg) refers to the temperature at which the device can be safely stored when the device is not powered. The ambient temperature refers to the temperature of the surrounding environment (typically air) when the device is powered. The junction temperature refers to the temperature of the silicon die within the device's package when the device is powered. The junction temperature can also be referred to as the operating temperature.
Resolution
Please refer to the appropriate device data sheets for the specific values and ranges of these different temperature specifications. More information can be found in the "Thermal Management" section in the Early Power Estimators (EPE) and Power Analyzer and AN 358: Thermal Management for FPGAs (PDF).
Updated 11 months ago
Version 3.0
