Knowledge Base Article
Warning (332174): Ignored filter at hps_sdram_p0.sdc(303): memory_mem_ck could not be matched with a clock
Description
Due to a problem in the automatically generated synopsys design constraints for the Arria® V/Cyclone® V Hard Processor System IP you may see this warning durng compilation or timing analysis.
The problem is caused by incorrect assignment order within the hps_sdram_p0.sdc file.
Resolution
To workaround this problem you can modify the following lines the hps_sdram_p0.sdc file.
 # This is the CK clock
 foreach { ck_pin } {
 set_clock_uncertainty -to [ get_clocks ] (WL_JITTER)
  create_generated_clock -multiply_by 1 -source -master_clock "" -name
 # This is the CK#clock
 foreach { ckn_pin } {
  create_generated_clock -multiply_by 1 -invert -source -master_clock "" -name
To:
This problem is scheduled to be resolved in a future release of the Quartus® II software.
Updated 11 months ago
Version 3.0
