Knowledge Base Article
VHDL error at <design>.vhd(): value cannot be assigned to constant "<constant name>"
Description
This error may occur when you assign values to specific bits of a generic. For example, this error can occur if you have the following declaration and then assign specific bits within a generic construct, as shown below.
generic(
reset_value : std_logic_vector(15 downto 0) ...
generic map(
reset_value(2) => '1',
reset_value(7) => '1',
reset_value(9) => '1', ...
The Quartus II software does not allow specific bits of a generic construct to be assigned. Instead, you must assign the entire generic construct, as shown in the following change to the generic map from the example above:
reset_value => "0000001010000100",
This problem is fixed beginning with the Quartus II software version 8.0.
Updated 10 months ago
