Knowledge Base Article
Unable to make preloader in Windows 10
Description
This issue comes when using the SOC EDS tool to generate the preloader. After creating the new HPS and BSP settings file, the make command is giving a failure:
tar zxf /cygdrive/c/intelFPGA/18.0/embedded/host_tools/altera/preloader/uboot-socfpga.tar.gz
tar: Error opening archive: Failed to open '/cygdrive/c/intelFPGA/18.0/embedded/host_tools/altera/preloader/uboot-socfpga.tar.gz'
make: *** [uboot-socfpga/.untar] Error 1
Resolution
In order to work around this issue, two files need to be modified before executing the make command.
1. C:\<installation_directory>\embedded\ip\altera\preloader\src\Makefile.template
Change the current file with the attached one in this link (make sure to unzip the file before you copy it)
2. C:\<installation_directory>\embedded\host_tools\cygwin\etc\fstabin
in fstab file: comment this line:
#non /cygdrive cygdrive binary,posix=0,user 0 0
and add this line instead:
none /cygdrive cygdrive binary,posix=0,user,noacl 0 0
This issue is scheduled to be fixed in the future release of  Intel® Quartus® Prime Software.
Updated 4 months ago
Version 4.0
