Knowledge Base Article
Unable to load all the programming files specified in //network_path/filename.cof
Description
You may be receiving this error message in the Quartus® II software if you are browsing to a network drive that contains your Conversion Setup Data file (.cof file). To open a .cof you will need to use a path which is on your local machine.
Resolution
Updated 11 months ago
Version 3.0
