Knowledge Base Article
This license cannot be checked out because: FLEXlm error message: "Invalid date format in license file (-11,31)".(FLEXlm)
Description
You may get this error message if your lmgrd.exe file is corrupt, or if you do not have the correct version ofLMGRD installed on your system. If you are using the MAX PLUS® II software version 9.2x, you must have version 6.0i or later of the LMGRD executable.
You can custom install the FLEXlm components only by choosing Custom Installation and installing the following:
- FLEXlm support files
- FLEXlm server files (these files are optional and need to be installed only if you are using the machine as a floating-license server)
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
