Knowledge Base Article
SEVERE: AutoSweepControllerPMAAnalog constructor rbc failure
Description
Due to a problem in the Quartus® II software version 10.0 SP1, this error may be generated when attempting to run an Auto-Sweep with the Transceiver Toolkit. Due to this problem, you may also see messages similar to:
java.lang.Exception: ALTERA INTERNAL ERROR: RBC error code (2)
at com.altera.systemconsole.transceivers.internal.RuleBasedCheckerJniInterface.get_legal_values(Native Method)
at com.altera.systemconsole.transceivers.internal.RuleBasedCheckerReconfigAnalogSolver.initializeTXDictionaryTreeWithRBC(RuleBasedCheckerReconfigAnalogSolver.java:949)
at com.altera.systemconsole.transceivers.internal.RuleBasedCheckerReconfigAnalogSolver.initializeTXDictionaryTree(RuleBasedCheckerReconfigAnalogSolver.java:915)
at com.altera.systemconsole.transceivers.internal.RuleBasedCheckerReconfigAnalogSolver.getDictionaryTreeRoot(RuleBasedCheckerReconfigAnalogSolver.java:801)
at com.altera.systemconsole.transceivers.internal.RuleBasedCheckerReconfigAnalogSolver.access./kdb00(RuleBasedCheckerReconfigAnalogSolver.java:776)
at com.altera.systemconsole.transceivers.internal.RuleBasedCheckerReconfigAnalogSolver.solve(RuleBasedCheckerReconfigAnalogSolver.java:100)
at com.altera.systemconsole.transceivers.internal.RuleBasedCheckerReconfigAnalogSolver.solve(RuleBasedCheckerReconfigAnalogSolver.java:95)
at com.altera.systemconsole.transceivers.internal.AutoSweepControllerPMAAnalog.GenerateRbcTestCases(AutoSweepControllerPMAAnalog.java:805)
at com.altera.systemconsole.transceivers.internal.AutoSweepControllerPMAAnalog.access./kdb00(AutoSweepControllerPMAAnalog.java:43)
at com.altera.systemconsole.transceivers.internal.AutoSweepControllerPMAAnalog.run(AutoSweepControllerPMAAnalog.java:172)
at com.altera.systemconsole.internal.core.SystemExecutor.run(SystemExecutor.java:318)
at com.altera.systemconsole.internal.core.SystemExecutor.run(SystemExecutor.java:436)
at com.altera.systemconsole.internal.core.SystemExecutor.run(SystemExecutor.java:207)
at java.util.concurrent.ThreadPoolExecutor.runTask(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
A patch is available to fix this problem for the Quartus II software version 10.0sp1. Download and install Patch 1.117 from the appropriate link below.
- Download the version 10.0 SP1 Patch 1.117 for Windows (.exe)
- Download the version 10.0 SP1 Patch 1.117 for Linux (.tar)
- Download the Readme for the Quartus II software version 10.0 SP1 Patch 1.117 (.txt)
This problem is fixed beginning with the Quartus II software version 10.1.
