Knowledge Base Article
Quartus Prime Software generates internal error when compiling Altera PHYLite for Parallel Interfaces IP core that does not use dynamic reconfiguration.
Description
Partitioned Altera PHYLite for Parallel Interfaces IP core that does not use Dynamic Configuration feature causes Quartus Prime software to generate an internal error during design compilation due to a bug in handling designs that do not use the IOAUX block.
Resolution
Do not use QHD partition or enable dynamic reconfiguration for Altera PHYLite for Parallel Interfaces IP core. This issue will be fixed in future releases.
Updated 10 months ago
Version 2.0
