Knowledge Base Article
Physical JTAG chain is not working when enabling the JTAG-Over-Protocol IP
Description
Due to a problem within the Quartus® Prime Pro Edition Software version 23.4 and earlier, you may see that the physical JTAG chain becomes inaccessible when utilizing the JTAG-Over-Protocol IP. As a result, the jtagconfig utility fails to detect any nodes.
Resolution
Do not use the physical JTAG chain. There is no solution to dynamically switch the JTAG drivers to the same JTAG based core logic.
Updated 5 months ago
Version 4.0
