Knowledge Base Article
{*Name Protected*} (*/stratixv_atoms.vhd: line 5355, position 21) and verilog parameter being overridden {*Name Protected*}.{*Name Protected*} (*/stratixv_atoms_ncrypt.v: line -1, position -1) are not type compatible.
Description
You may see this error when simulating a VHDL design in the Cadence NC-Sim software if the VHDL instantiates lower level Verilog HDL files.
Resolution
To avoid this error, use the -namemap_mixgen option with the ncelab command.
Updated 11 months ago
Version 3.0
