Knowledge Base Article
Is there any issue when instance the DDR3 hard IP core?
Description
Yes, there is an issue when instance the DDR3 hard IP core with these ports:
mp_cmd_clk_0_clk, mp_rfifo_clk_0_clk, mp_wfifo_clk_0_clk.
Resolution
Remove these ports from the top level when instance the DDR3 hard IP core if not use, or drive them by a clock buffer .
For example to add clk buffer like this:
wire  clk_source;
altclkctrl #(  .clock_type("GLOBAL CLOCK"), .number_of_clocks(1) )
global_clk_inst1 ( .inclk(clk_source),.outclk(mp_cmd_clk_0_clk));.
Updated 11 months ago
Version 3.0
