Knowledge Base Article
Internal Error: Sub-system: VRFX, File: /quartus/synth/vrfx/verific/vhdl/vhdlvalue_elab.cpp, Line: 6595
Description
This error may be generated by the Quartus® II software versions 10.0 and 10.0 SP1 when compiling VHDL source files which use arrays.
A patch is available to fix this problem for the Quartus II software version 10.0 SP1. Download and install Patch 1.133 from the appropriate link below.
This problem is fixed beginning with the Quartus II software version 10.1.
Updated 4 months ago
Version 5.0
