Knowledge Base Article
Internal Error: Sub-system: SDR, File: /quartus/sld/sdr/sdr_tx_editors.cpp, Line: 1046
Description
Due to a problem in the Quartus® II software version 13.0 SP1 and earlier, you may see this error if your SignalTap™ II Logic Analyzer has a trigger condition which includes a node name that contains a "\".
Resolution
To avoid this problem, do not use nodes whose names include a  "\" in the trigger condition.
This problem is fixed beginning with the Quartus II software version 13.1.
Updated 11 months ago
Version 3.0
