Knowledge Base Article
Internal Error: Sub-system: PUTIL, File: /quartus/power/putil/putil_cyclonev_hssi_info.cpp, Line: 610
Description
Due to a problem in the Quartus® II software version 13.1, you may see this Internal Error while running the PowerPlay Power Analyzer.
Resolution
To work around this problem, download and install patch 0.36 from the links below. You must install the Quartus II software version 13.1 before installing this patch.
- Download the version 13.1 patch 0.36 for Windows (.exe)
- Download the version 13.1 patch 0.36 for Linux (.run)
- Download the Readme for the Quartus II software version 13.1 patch 0.36 (.txt)
This problem is scheduled to be fixed in a future release of the Quartus II software.
Updated 4 months ago
Version 4.0No CommentsBe the first to comment
