Knowledge Base Article
Internal Error: Sub-system: PAN, File: /quartus/power/pan/pan_utility_impl.cpp, Line: 619
Description
Due to a problem in the Quartus® II software version 10.0 SP1, this error may be seen when you run PowerPlay Power Analyzer if the project enables vectorless estimation and has any Power Toggle Rate Percentage assignments.
A patch is available to fix this problem in the Quartus II software version 10.0 SP1. Download and install patch 1.208 from the appropriate link below:
This problem is fixed beginning with the Quartus II software version 11.0.
Related Articles
Updated 4 months ago
Version 4.0
