Knowledge Base Article
Internal Error: Sub-system: MLS, File: /quartus/synth/mls/mls_process_tri.cpp, Line: 5986
Description
Due to a problem in the Quartus® II software version 13.0 SP1 and earlier, you may see this error if your design has a pin that is diven by a tri-state signal and is also driven by a constant.
Resolution
To work around this problem, do not drive a pin with two signals.
This problem is scheduled to generate an error message in a future release of the Quartus II software.
Updated 11 months ago
Version 3.0
