Knowledge Base Article
Internal Error: Sub-system: FMAIN, File: /quartus/fitter/fmain/fmain_location_constraint.cpp, Line: 2494
Description
This problem may be seen when you perform an ECO (Engineering Change Order) for designs with LogicLock regions in Quartus® II software versions 9.1 SP2 or earlier.
To work around this problem, disable all LogicLock regions before performing ECO.
If you then need to run a full compilation from HDL, re-enable the LogicLock regions.
This problem is fixed in the Quartus II software version 10.1 and later.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
