Knowledge Base Article
Internal Error: Sub-system: B2T, File: /quartus/tsm/b2t/b2t_generic_atom_translator.cpp, Line: 244
Description
Due to a problem in the Quartus® II software, you may see this internal error when you import a Quartus II exported partition file (.qxp) with placement and routing.Resolution
To work around this issue, export a post-fit netlist but do not export routing.Updated 11 months ago
Version 3.0No CommentsBe the first to comment
