Knowledge Base Article
I compiled my design and it worked in the lab. I’ve re-compiled the same RTL in the same version of Quartus® II software and it doesn’t work. What could be wrong?
Description
Check the following common trouble areas which can affect a design that can be impacted by marginal changes:
  1. Analog Phenomenon:
·         Power & ground not within specification
·         Insufficient decoupling
·         Noise / Signal Integrity
  1. Timing Constraints
·         Incomplete constraints
·         Inaccurate constraints
·         Poor timing exception constraints
  1. Improper handling of async interfaces
·         Use Design Assistant to verify your design – You can find useful information to help resolve problems
·         Reset structures
·         Asynchronous clock domain transfers
·         Asynchronous signals
    Updated 11 months ago
    Version 3.0
