Knowledge Base Article
How do I use all of the available clocking resources in Stratix™ devices with the Quartus® II software version 2.0?
Description
Stratix devices have 24 clock pins: 16 dedicated clock pins that can either drive global or regional clock networks and 8 fast regional FCLK pins that can drive fast regional clock networks.
Because you cannot access all of the clocking resources through the pins, you have to use the dedicated pins together with phase-locked loop (PLL) outputs and internal logic routed to global resources to use all the clock networks in the device. Table 1 lists the global clock inputs.
Table 1. Stratix Clock Inputs
ClockInput
16 dedicated global clocks
  • Dedicated clock pins
  • Internal logic
  • PLL outputs
16 regional clocks
  • PLL outputs
8 fast regional clocks
  • Fast regional clock pins
Use the Assignment Organizer in the Quartus II software to make regional and fast regional clock assignments because there is no HDL primitive available for them. Use the GLOBAL primitive to make dedicated global clock assignments (you can also use the Assignment Organizer in the Quartus II software). See Quartus II On-Line Help for more information on the GLOBAL primitive. See the Stratix Device Family Data Sheet in the Stratix Device Handbook for more information on the global routing structure in Stratix devices.
Updated 1 month ago
Version 2.0
