Knowledge Base Article
How do I speed up my Verilog HDL simulation time in the ModelSim® software?
Description
By default, the ModelSim software runs in a debug-optimized mode. To run the ModelSim software in speed-optimized mode, add the following two vlog command line switches:
vlog -fast -05
In this mode, module boundaries are flattened and loops are optimized. This eliminates levels of debugging hierarchy, which may result in faster simulation.
This switch is not supported in the ModelSim-Altera® simulator.
Updated 1 month ago
Version 2.0
