Knowledge Base Article
How do I specify different timing constraints for TimeQuest, Fitter, or Analysis & Synthesis?
Description
To identify which executable is currently running you can use the $::TimeQuestInfo(nameofexecutable) command from within a Synopsys Design Constraints (.sdc) file. This method can be used to specify different .sdc assignments or files for specific executables as shown in the following .sdc examples:
#Identify which executable is running:
set current_exe $::TimeQuestInfo(nameofexecutable)
if {$current_exe == "quartus_fit" } {
    #Apply .sdc assignments for Fitter executable here
} else {
    #Apply .sdc assignments for non-Fitter executables here
if { ! [string equal "quartus_sta" $::TimeQuestInfo(nameofexecutable)] } {
    #Apply .sdc assignments for non-TimeQuest executables here
} else {
    #Apply .sdc assignments for TimeQuest executable here
Examples of different executable names are quartus_map for Analysis & Synthesis, quartus_fit for Fitter, and quartus_sta for the TimeQuest timing analyzer.
Updated 11 months ago
Version 3.0
