Knowledge Base Article
How do I estimate the current drive strength of the I/O buffer when using series on-chip termination (OCT)?
Description
Many Intel® FPGAs have output pin configuration options which allow you to select either current drive strength or series on chip termination (OCT).  Although these have  different settings in the Intel Quartus® Prime software, they use the same structures in the output buffer to implement the desired setting.
Download this How-To document to learn how you can use IBIS models to estimate the current strength of the series OCT settings.
Related Articles
Updated 4 months ago
Version 4.0
