Knowledge Base Article
How do I add files to my project using a TCL commands?
Description
You can add files to your Quartus® II project using Tcl commands by making the appropriate assignments.
For example, use the following commands to add Verilog HDL files to your project individually:
set_global_assignment -name VERILOG_FILE <filename 1>.v
set_global_assignment -name VERILOG_FILE <filename n>.v
File assignment names include VHDL_FILE, VQM_FILE, and BDF_FILE, and others based on the file type to be added.
You can also use a loop to add all design files of a particular type in a directory. For example, use this code sample to add all Verilog HDL files in the current directory to the project:
foreach verilog_file {glob *.v} {
Updated 3 months ago
Version 2.0
