Knowledge Base Article
How can I perform a Remote System Update on a Cyclone III or Cyclone IV device over a JTAG to Avalon MM Master Bridge?
Description
The Remote System Update IP Core for Cyclone® III or Cyclone IV devices provides an Avalon MM (AVMM) interface to read and write to the core control and status registers to perform a successful configuration update. This can be done with a compatible AVMM Master component available in Quartus® Prime software without the need for an on-chip processor.
The JTAG-Avalon MM Master Bridge forms a direct interface between the user and the remote system update IP core, which allows users to perform reconfiguration via System Console over JTAG interface.
The Remote Update IP Core Avalon-MM Registers that need to be configured over JTAG, while updating the configuration from a factory image to an application image are :
  1. Write to RU_WATCHDOG_TIMEOUT
    • Address offset is 0x20
    • Write a 12-bit timer value
  2. Read back from this register can be done to see if the watchdog timer value is written correctly .
    • Address offset is 0x2C
    • Reads back the 12-bit timeout value
  3. Write to RU_WATCHDOG_ENABLE
    • Address offset is 0x30
    • Write 0x1 to Enable or 0x0 to Disable the Watchdog Timer
  4. Write to RU_BOOT_ADDRESS
    • Address offset is 0x40
    • Write a 32 bit start address which points to the start of the application image stored on the flash device. The FPGA shall boot from this address once reconfiguration is triggered. For example : 0x00400000
  5. Read back from this register can be done to see if the boot address for application image is written correctly.
    • Address offset is 0x4C
    • Reads back the 32 bit boot address.
  6. Write to RU_RECONFIG
    • Address offset is 0x74
    • Write 0x1 to trigger a reconfiguration
Once a reconfiguration is triggered, the System Console loses its connection to the FPGA over JTAG. Users would need to launch a new session of System Console once the FPGA boots from the application image to re-establish a valid JTAG chain.
Updated 11 months ago
Version 3.0
